I try to investigate a program written by a former collegue.
An 8-bit dipswitch is connected to the microcontroller address/data bus. Two variables are declared in an assembler file: public DIPSWITCH and public _DIPSWITCH. The dipswitch value is read bij an assembler file from address DIPSWITCH (the real hardware address) and stored in _DIPSWITCH. (_DIPSWITCH is to be used as the startup dipswitch value and DIPSWITCH is used as the real actual value). In a .C file both DIPSWITCH and _DIPSWITCH are declared as 'extern xdata unsigned char'. If I evaluate the startup value _DIPSWITCH in that .C file I get the actual value of DIPSWITCH. If I create only two code-lines:
if ( _DIPSWITCH){ do something} if ( DIPSWITCH){ do something}
and then I compile that source with '#pragma src' and look in the listfile I see:
MOV DPTR,#_DIPSWITCH MOV DPTR,#_DIPSWITCH
So both different .C source lines compile to the same assembler code.
Can someone explain this?
Henk
Can someone explain this? sure, but to no avail.
you need familiarize yourself with the chip or you will be lost after the next step.
read "the bible" (in this case, especially ch2)
erik
here are the links to "the bible" Chapter 1 - 80C51 Family Architecture: Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
Seems like I would have to spend time with the bible - does it really has the answer to this? - because I find this a bit curious.
The C compiler should normally add a leading underscore on all symbols with external linkage, i.e. symbols that may be shared between separate compilation units, so a variable DIPSWITCH in C would be mentioned as _DIPSWITCH when linking with other object files.
This allows startup and runtime library files to use variables without a leading underscore, without creating a name-space collision with end-user application code.
For a "normal" assembler/compiler, the assembler symbol DIPSWITCH would not have been acceccible in C, unless you used a special compiler switch to request that no leading underscore should be added.
For a "normal" assembler/compiler, the assembler symbol _DIPSWITCH should have been accessible in C using the name DIPSWITCH.
That both DIPSWITCH and _DIPSWITCH in C got translated into _DIPSWITCH in assembler sounds like a Keil-specific feature, unless the 8051 bible has any section about special treatment of leading underscores for the 8051 target platform.
