Programming LPC 2388
I have developed LPC2388 Board, The power supply is fine and even i am able to download the program on the board, once dwonloading problem was solved i wrote a sample program which will make all the ports pins on all port low...but when i checked the volatge on the PINS it always show 2.3volts. my feeling is i am making mstake in configuring the prots pins properly,
I would really appreciate if some one can provide a sample program which makes all the ports pins high and low...
Thanking you in advance
  • Hello all,
    i have exactly the same problem.
    I also have 2.3v on pins.
    Is your oscillator running.
    Here on my board it isnt and i dont know why.
    (Resetpin is high resetout and ISP (p2.10) are high too)
    Have you solved your problem already? Im very intrested in getting my controller running.
    Thanks in advance!
  • Hello all,
    Thanks in advance!
