startup edit in lpc2138
hai all,
I m doing rtos programming which is based on osek standard for LPC2138.
In that i need to enter the supervisor mode for running the tasks & all my code must runs under svc mode. but main prog is running in user mode if i use the startup.s in the keil.
so i had changed the startup.s to run the main in svc mode by commenting the usermode stack initialization. Now it is running under SVC mode. but the problem is when i enter into IRQ mode i call some user functions through asm & changing the mode into SVC to save task stack back into IRQ mode , at that time the global variables are changed.Pls give some tech ass regarding this issue.(I need the global variables won't change )
Thanks in advance,
yos
