Can I change the location of INIT.A51?
How can I locate the INIT.A51 code at e.g 0x1000?
Is it a usual segment?
Does the INIT.A51 do anything except initialize static vars?
(The problem is that I want to use a bootloader and 2 images. First the bootloader's startup and init.a51 code will run, then the bootloader code and then I want it to jump to the correct image and initialize the static variables of the specific image chosen...)
