i am doing project on AT91SAM9260 controller, but when i am trying to download executable file using JLINK it fails with:
No Algorithm found for: 20000000H - 20000B2FH
Here's the log output:
Build target 'Target 1' compiling main.c... compiling board_memories.c... board_memories.c(109): warning: #61-D: integer operation result is out of range compiling board_lowlevel.c... compiling pio.c... assembling board_cstartup_keil.s... compiling pmc.c... compiling cp15.c... assembling cp15_asm_keil.s... linking... Program Size: Code=2824 RO-data=40 RW-data=0 ZI-data=8192 User command #1: fromelf.exe --bin -o E:\myproject\myproject.bin E:\myproject\myproject.axf "myproject.axf" - 0 Error(s), 1 Warning(s). Load "E:\\myproject\\myproject.AXF" VTarget = 3.261V Info: TotalIRLen = 4, IRPrint = 0x01 Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D112112: ICache: 8kB (4*64*32), DCache: 8kB (4*64*32) Info: Cache type: Separate, Write-back, Format C (WT supported) Info: RTCK reaction time is approx. 126ns Info: Auto JTAG speed: Adaptive Info: J-Link: ARM9 CP15 Settings changed: 50078 from 78, MMU Off, ICache Off, DCache Off Info: TotalIRLen = 4, IRPrint = 0x01 Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D112112: ICache: 8kB (4*64*32), DCache: 8kB (4*64*32) Info: Cache type: Separate, Write-back, Format C (WT supported) DLL version V4.08b, compiled Jun 30 2009 19:10:31 Firmware: J-Link ARM V8 compiled Jun 30 2009 11:00:16 Hardware: V8.00 Hardware-Breakpoints: 2 Software-Breakpoints: 2048 Watchpoints: 0 Found 1 JTAG device, Total IRLen = 4: Id of device #0: 0x0792603F ARM9 identified. Using adaptive clocking instead of fixed JTAG speed. Info: TotalIRLen = 4, IRPrint = 0x01 Info: CP15.0.0: 0x41069265: ARM, Architecure 5TEJ Info: CP15.0.1: 0x1D112112: ICache: 8kB (4*64*32), DCache: 8kB (4*64*32) Info: Cache type: Separate, Write-back, Format C (WT supported) Using adaptive clocking instead of fixed JTAG speed. No Algorithm found for: 20000000H - 20000B2FH Erase skipped!
Google returns a few results for "keil no algorithm found for" e.g.
http://www.keil.com/support/docs/2831.htm
If that doesn't help investigate some of the others.
this nomally means that you forgot to select an algorithm in the third tab of the target driver configuration dialog (utilities -> select JLink driver -> 'Add' and select "your" flash algorithm from the list.
That should work. If not, please report this problem to keil support, and I'll solve it when I'm back next week.
BR, /th.
hi,
i had tried to add algorithm in utilities -> select JLink driver -> 'Add' and select "your" flash algorithm from the list.but i didn't find any algorithm for AT91SAM9260 (SDRAM). can you help me out to solve this problem
I think it can also mean that your memory set-up is wrong?
As the message suggests, the Algorithm needs to be correct for the specified address range - so, if the address range is wrong, you can get this message.
I have a feeling that the Algorithm could be one of those things that uVision-3 stores in the "wrong" file; ie, it stores it in the project.opt file, rather than the project.uv2 file?
This means that, if you save/copy just the project.uv2 file, you lose the Algorithm setting and, therefore, you are likely to get this error the first time you try to debug...
