read
http://www.keil.com/forum/docs/thread16135.asp
"pak pak pak" !
the usual (this may come as a surprise to you) way to handle "CODE NEDEED" is to write it.
http://codesearch.google.com
I think this will help.
;It is important that the DCF77 reception is optimal. ;For DCF77 info, schematic diagram and control: http://www.8051basic.nl ; 80ZNS51LP: +--v--+ ; Pulse for gong E1 <[ ]> One pulse per second ; Pulse for gong E2 <[ ]> Daylight saving, high when it's summer ; Volume level gong <[ ]< Connect LDR to +5V, 1M potmeter to GND ; [ ]< 12:00 (AM/PM) or 24:00 notation ; GND [ ] +5V ; DCF77 module signal >[ ]> DB7 LCD ; Normaly open, for test to GND >[ ]> DB6 LCD ; LCD EN <[ ]> DB5 LCD ; LCD RS <[ ]> DB4 LCD ; +-----+ ;Er is ook een Nederlandse versie / There is a Dutch version too ;http://www.8051basic.nl / Frits Kieftenbelt, Raalte, Netherlands (Frizie)
Thank.
I cant get to the site. It is it down?
