Hello, We are thinking about switching from 8051 to Cortex M3. At the moment everything is written in assembler. Now I simply would like to know, how many assembler statements a Cortex M3 CPU will take to evaluate a square root from a 48 Bit integer value. Is this (square root of a 48 Bit integer) included in a math library and a nobrainer or is only floating point supported. I am new and just evaluating, what the switch means for us, so I would highly appreciate to get an answer to this question.
Thanks a lot.
Uwe Renschler
I think it's safe to expect the standard C library functionality - no more, no less. There are some extensions, but they are not related to square roots: http://www.keil.com/support/man/docs/armlib/armlib_chdeifcf.htm You can count on 'double sqrt(double)' and 'float sqrtf(float)'. But surely it would be easy to port the existing square root of integer routine from 8051 assembly to C?
A fixed point implementation of SQRT is trivial to implement using 64-bit integers.
Nice to hear that a fixed point sqrt is trivial. I hope that it is also trivial to get the answer to my question: How many assembler statements are executed from a Cortex M3 CPU to figure out the square root of a 48 Bit integer value ? (min, max values if variable) What I read so far, is that the library could be used. And that is really trivial. But I don t know, what the library looks like and the 48 Bit square root is in our application performance critical. (At the moment we have implemented it using a 128 Entry lookup table and it takes between 40 and 60 8051 assembler statements). The same like in the brackets before would I like to know, for the Cortex M3 with the standard math lib.
I never worked with a 8051, however I can assure you that the M3 is lighting fast compared to it. I am confident that you'd be delighted with the calculation speed.
I meant: "lightening fast", of course.
No; I think you really meant, "lightning fast"...?
