I'm trying to compile my program but I get this error message at then end of the compilation C:\Programme\Keil\ARM\RV31\INC\RTX_Config.h(18): error: #35: #error directive: New RTX-V2 core does not require RTX_Config.h
I'm working now with Keil uvision4. This problem appeared when I changed the version of Keil, because I was working before with Keil version 3.
I think I have to chande the ARM folder, but I don't find a new RTX_Config for this version. Does someone have had the same problem???
Try C:\Keil\arm\startup\philips for RTX_conf.c file. RTX_Config.h is no longer needed. If you look at the RTX_Conf.c you should be able to determine why it is not longer needed.
Might not the message try to tell you that the new RTX doesn't require any such file?
After all, the message says: "does not require RTX_Config.h".
So is there then a reason why you expect that you should be able to find any such file?
I have tried to find the new version of RTX_Config for lpc2368, but no success at all. Could you tell me how or where could I download the new version?
a quick guess: a very old RTX/RL-ARM...?
