Hello everyone, this is my first time I'm programming any microcontroller, my task is probably quite simple - I have to use nested interrupts. I'm using interrupt from Timer0 nad ADC. I have to run ADC interrupt during executing Timer0 ISR. I've read AN1381 document and many others but I still have problem. I've tried to use intrinsic functions __enable_irq and __disable_irq, wrapper for nested interrupt functions (exactly like in example from Keil), and i still have the same problem - ADC ISR is executed after Timer0 interrupt. I've also tried to use embedded assembler functions. Below is my actual code:
main.c:
#include <LPC21xx.H>
void initVIC(void); void initTimer0(void); void initADC(void); void initUART(void); void initGPIO(void); int sendchar(int); void sendUART(float);
__irq void irqTimer0(void) { int i; __enable_irq(); ADCR |= 0x01200000; for(i = 0; i < 10000; i++); __disable_irq(); T0IR = 0x00000001; VICVectAddr = 0; }
extern void adc_irq (void); void irqADC(void) { float Uout; IO1SET = 0x00010000; Uout = ((ADDR>>6)&0x3FF)*3.3/1023; ADCR &= ~0x01000000; ADCR &= ~0x00200000; sendUART(Uout); VICVectAddr = 0;
int main(void) {
initVIC(); initTimer0(); initADC(); initUART(); initGPIO();
while(1) {
void initVIC (void) { VICVectAddr0 = (unsigned int) irqTimer0; VICVectCntl0 = 0x00000024;
VICVectAddr1 = (unsigned long)adc_irq; VICVectCntl1 = 0x00000032;
VICIntEnable |= 0x00040010; }
void initTimer0(void) { T0PR = 14999; T0MCR = 0x00000003; T0MR0 = 100; T0TCR = 0x00000002; T0TCR = 0x00000001; }
void initADC(void) { ADCR = 0x00000300; }
void initUART(void)... void initGPIO(void)... int sendchar(int)... void sendUART(float)... I'm sure that these functions are correct so I'v reduced them
nest_irq.s: exactly like in Keil's example
PRESERVE8
AREA NEST_IRQ, CODE, READONLY
ARM
IMPORT irqADC
EXPORT adc_irq
adc_irq
PUSH {R0-R3,R12,LR}
MRS LR, SPSR
PUSH {LR}
MSR CPSR_c, #0x1F
BL irqADC
POP {LR}
MSR CPSR_c, #0x92
MSR SPSR_cxsf, LR
; VICVectAddr = 0;
MOV R0,#0
STR R0,[R0,#-0xFD0]
POP {R0-R3,R12,LR}
SUBS R15,R14,#0x0004
END
I'll be very grateful if someone could post a code wher nested interrupts are working properly and also for every comment that may help to solve my problem.
