I have a windows app that sends the following 8 bytes to the NXP LPC2478 UART2 at 38400, 8 bits 1 stop.
01 06 02 00 01 03 09 9B
Once received the NXP echos these bytes back to PC.
What I get back is 01 06 02 00 01 03 09, the 9B is missing. If I send the bytes again then the echo starts with 9B followed by most of the bytes sent. If byte 2 is changed from 02 to 03 or greater then the echo is always correct. If byte 2 is 01 then the first time I get 01 06 01 00 01 03, this time missing 09 and 9B. Sending the command again I then first get the 09 9B followed again by some or all characters send. I have enabled only Rx interrups and both Rx and Tx interrups, does not matter.
