Hello, I am new to ths processor to this is a rather difficult situation...If my bootloader uses CPU peripheral T0 (not interrupting, just a free running timer), T0 must be stopped just prior to jumping to the application in order for the application code (that uses an interrupting T0) to get interrupted by the CPU, otherwise it won't. If I initialize USB in the bootloader, resetting the peripheral does not help; the application should be interrupted by T0 but is not! but If my bootloader jumps directly to the application all is well. Do you have a clue?
ok, I have booked some progress. resetting all peripherals using the PCONP register (and reconfiguring in the application) seems to solve the problem. Please provide your insite if you have something to add...
