Dear all,
I use the new AT91Lib 1.5 that includes some Keil samples. These samples use a scatter loading file with the foloowing memory definitions:
Load_region 0x100000 0x80000 { Fixed_region 0x100000 0x80000 { *(cstartup +First) .ANY (+RO) } Relocate_region 0x200000 { *.o (VECTOR, +First) .ANY (+RW +ZI) } ScatterAssert(ImageLength(Relocate_region) < 0x6000) ARM_LIB_HEAP 0x206000 EMPTY 0x1000 { } ARM_LIB_STACK 0x208000 EMPTY -0x1000 { } }
Now I need some more stack and heap. But everything I tried did not succeed. In an older project I defined stack and heap in the startup code as followed:
;// <h> Stack Configuration (Stack Sizes in Bytes) ;// <o0> Undefined Mode <0x0-0xFFFFFFFF:8> ;// <o1> Supervisor Mode <0x0-0xFFFFFFFF:8> ;// <o2> Abort Mode <0x0-0xFFFFFFFF:8> ;// <o3> Fast Interrupt Mode <0x0-0xFFFFFFFF:8> ;// <o4> Interrupt Mode <0x0-0xFFFFFFFF:8> ;// <o5> User/System Mode <0x0-0xFFFFFFFF:8> ;// </h> UND_Stack_Size EQU 0x00000000 SVC_Stack_Size EQU 0x00000008 ABT_Stack_Size EQU 0x00000000 FIQ_Stack_Size EQU 0x00000000 IRQ_Stack_Size EQU 0x00000080 USR_Stack_Size EQU 0x00002000 ISR_Stack_Size EQU (UND_Stack_Size + SVC_Stack_Size + ABT_Stack_Size + \ FIQ_Stack_Size + IRQ_Stack_Size) AREA STACK, NOINIT, READWRITE, ALIGN=3 Stack_Mem SPACE USR_Stack_Size __initial_sp SPACE ISR_Stack_Size Stack_Top ;// <h> Heap Configuration ;// <o> Heap Size (in Bytes) <0x0-0xFFFFFFFF> ;// </h> Heap_Size EQU 0x00002800 AREA HEAP, NOINIT, READWRITE, ALIGN=3 __heap_base Heap_Mem SPACE Heap_Size __heap_limit
I use the Atmel SAM7SE512 Processor that has 32kbytes of RAM.
Does anybody knows how to change ARM_LIB_HEAP and ARM_LIB_STACK?
Big thanks,
Christian
