I'm using ADuC7026's I2C to interface with AD5254 (digital potentiometer). Every once in a while, I get a bad pulse on the SCL line, and the AD5254 does not acknowledge the byte. The bad pulse is essentially a pulse that only rises 40-50% of the normal logic level (3.3V). Subsequently, the SDA line remains low, and I must do a hard reset of the micro to get the line back to it's high logic level.
This condition seems to occur more frequently when I'm interfacing with a host PC through the ADuC7026's serial port.
Any help would be appreciated. Matt.
What happens if you deactivate the I2C and then manually clock out a number of clock bits until you get back to a stable state? I2C recovery should be part of a I2C implementation.
I'm not quite sure how to manually detect these conditions and manually send out clock pulses. Would I be waiting for the slave to acknowledge, or would I be monitoring the SDA line for it to behave properly?
Is this a common occurrence, that clock pulses are not as desired?
How common it is depends on the hardware, the baudrate, the length of the traces etc. But a robust solution should detect when you can't talk with your I2C devices anymore and clock them to a known state. Remember that the I2C listeners are state machines. They count bits in the transfer, so an extra clock signal will have them hung waiting for the remaining data bits. They don't have any timeout - all time they see is the number of clock pulses.
I will attempt to implement this recovery routine, thanks for the heads-up.
But to further diagnose where the source of the problem is, how could I post a screenshot from the oscilloscope showing the i2c lines? What i'm seeing is that one of the clock pulses rises to approximately 1.5V, then gets pulled low immediately. Normally, clock pulses rise to 2.85V (using a 3.3Vcc system). As I understand, the SCL line is wired-AND.
You would have to put it somewhere accessible, then post a Link to that.
Please don't choose a site that gives hordes of pop-ups, adverts, etc, or requires registration...
www.dropbox.com ?
I've posted the screenshot at "nilessa (dot) ca"
Do you have correct pullup resistors for your signals? All your signals looks like shark tooths. As you can see, the rise time is too long for the clock signal to ever stabilize at a high state. The data signal has also a hard time reaching a high state.
Do you use hardware or software I2C? If hardware I2C - do you have anything that may reset the I2C controller?
I am using the I2C interface embedded in Analog Device's ADuC7026 microcontroller. I am not generating clock/data pulses in software, but relying on the micro for that.
There are 10kOhm pull-ups on each line. We're going to replace them soon for 1kOhm pull-ups.
