A memory question on Atmel AT89C51CC03
From the data sheet, it says the Atmel AT89C51CC03 has 256 bytes RAM and 2048 byte ERAM. When I use Keil compile my code, at the end, Keil says data = 105, xdata = 2285...
There is no other warning, but should xdata be less than 2048? I am just wondering if this is the root cause of my problem.
Thanks,
