I want to do data logging for GPS data in serial memory AT24C512 for this purpose,i need to make a circular buffer in serial memory.
Could some body please post the code now and algorithm for real-time circular buffer so that data may be stored in circular buffer and may be read or retrieved at will.
Data need to be continuously stored over circular queue while data is retrieved from queue only on demand
regards m.yasir
catb.org/.../smart-questions.html
If it's that urgent, why don't you just take one of the many examples that's already available on this very site!
The interrupt-driven serial IO examples use circular (or "ring") buffers...
How much data and in how big blocks and how many updates woult that result for the serial memory? How many rewrites does your serial memory support? What alternatives do you see for getting an even wear of the serial memory? Have you tried to implement it?
Yasir,
Never forget this advise, given by one of the humans brightest ever:
The mere formulation of a problem is far more essential than its solution. . .
-Albert Einstein
I meant, of course:
Never forget this advise, given by one of the brightest humans ever...
Tamir: Can we assume that you like your RPN calculator and prefer programming in Forth ;)
What I think you really meant was:
"Never forget this advice, given by one of the brightest humans ever..."
Remember - Bad spelling in your code could cost lives!
With your spellings - more care you must take!
so u havent had any answers from the 'professionals' and i dont think the einstein quoter can to help u.
GOOGLE makes an awesome first resource for such needs.
www.google.com/search
In the list I found this: en.wikipedia.org/.../Circular_buffer Which includes source code and a thorough explanation.
also , see the gps logger application here also uses circular buffer techniques
frank.circleofcurrent.com/.../gps_logger.htm
But Einstein would notice that your links don't seem to bother too much with the wear on the serial memory. OK if the serial memory is FRAM. Not so good if the serial memory is flash. Semigood if the serial memory is EEPROM. In some cases acceptable if the serial memory has automatic wear leveling.
That is one of the reasons why the OP was requested to supply a bit more information, and to consider the implications of the wear issues. The OP hasn't responded, so no one have seen an interest in trying to speculate in the OP:s needs. Especially since this was an urgent matter and we have to assume that the OP picked up the wallet and payed a consultant for immediate help. We poor sods on this list just don't have the available time to instantly produce turnkey code whenever someone posts an urgent request.
Wouldn't we be more unprofessional if we ignored the wear problem and just gave a link to a standard RAM-based ring buffer, like you did?
Links for what I want.
tnahks m.yasir
Have you figured out yet how fast you can wear down the memory?
we have done the math and get 11.2 years.
How do you perform the wear leveling? The rotating data has natural wear leveling but if you have read and write indices stored in the same address, they will not get any wear leveling unless the serial memory has internal wear leveling.
If that's not sufficient, what do you require?
the index will be in ram and we determine the number on starting reset.
