I am using AT89C55WD microcontroller.I need to set the baud rate 115200bps.For that what should I write in TH1 timer(TH1=?) The crystal frequency is 11.0592 MHz.
go for controller's datasheet.........there must be a formula given........or u can refer to some book on at89c55wd
even easier the Keil baudrate calculator
