Dear All,
I am using Silabs 8051F340 micro controller and USB debug adapter to download the code to my target CPU.
The problem i am facing is my code works fine when i reset the system using my debug adapter by keeping adapter connected to target CPU. But once i remove the debug adapter from system and switch on system on independent power supply; it shows erratic behavior and doesn't work properly.
Note: My system doesn't have RESET switch. But i feel power on RESET is okay..
Kindly suggest me.
Thank you, Ameya
Why do you feel your target reset is working?
Have you looked at the reset pin with a scope while in the power up mode?
How are you providing a reset signal on your target board? Bradford
i had a problem where my code worked fine if there was a breakpoint. When let run free it would work fine and recieve a command from the uart once then crash when i send a second command. Turned out to be with breakpoints set it caused enough of a delay to skip a byte comming into the uart. Never noticed it because that byte would be disgarded in processing anyway. It took one extra line of code to fix after 2 days of hair pulling. When let run free the extra byte caused the program to crash...
So it could be a similar timing issue. But you dont describe the eratic behaveior. Also if you dont have an rc reset circuit or a reset chip, i'd add one.
No, this does not sound like a sw error. This very much sounds like an incorrectly driven reset line.
but the SILabs derivatives (f0x-f2x) require a resistor (I use 2k2) from the reset pin to Vcc to have a reliable power on reset.
"SILabs derivatives (f0x-f2x) require a resistor (I use 2k2) from the reset pin to Vcc to have a reliable power on reset"
Do you consider that a sufficiently reliable reset, or would you still recommend an external reset-generator (or "supervisor") chip?
I'm just asking - I don't know!
"Code only works with Debug adapter"
With these key words, I remember these causes and solutions.
a) Noise to the reset (C2CK) and/or C2D pins - pull up both pins. b) Slowly-rising power supply - solved by an external supervisor chip to the reset pin. c) Broken GND connection - just the debug adapter gives GND connection to PC
Tsuneo
I have 1000s of single processor boards where this works without a glitch.
My 'theory' about built-in resets is that chips with a lot of analog have good built-in resets whereas for chips where the reset is the only analog feature it is usually lousy.
