MDK-ARM 4.0
Hi All
I am using the MDK micro version 3.3 , now i downloaded the MDK-ARM4.0 and installed it, open my project in version 4.0 and compile it working fine but when i try to download the code using ulink2 i get any error stating "EEROR : Flash Download Failed-This old version of 'SARM.DLL' is incompatible with the version (UV3.EXE)
Please use a consistent installation.
Plz advice on this i am not able to load using this .
Regards
Suresh
  • Hello,
    uVision4 Beta 1 is not compatible with MDK-ARM 3.3 and other older uVision toolchains.
    Please upgrade your toolchain to the latest version in order to try the uVision4 Beta.
    To update, simply go to the 'Help->Check for Update...' option in uVision3, or visit:
    http://www.keil.com/update/
    If you have already installed uVision4, don't worry. Just install the toolchain upgrade in the same folder and then uVision4 should work.
    Richard
  • Hello,
    Richard
