i m attaching a circuit diagram which is step down the 220V AC to 7-8 A DC (AC?)
can anyone explain the working of the 1 M ohm resistance and 1uF capacitor ,how they work and step down the voltage?
Err ... no, you're not. This forum doesn't take attachments.
Besides, what does the question have to do with Keil tools?
my bad!
grab it from rapidshare
Still bad: you haven't explained what this has to do with Keil Software Tools...
I suspect that the answer could possibly be formed by combining the words "whatsoever" and "nothing" in an appropriate sequence...
From the text, this sounds like one of the non-isolated solutions where you produce a low level voltage with a capacitor. Possibly nice for a night lamp, but quite dangerous since the potential relative ground is hurtful.
Always use a real isolated power supply, if you care about your life.
extremely dangerous since the potential relative ground potentially can kill you.
Ah, but you live in a low-voltage country. :)
Less danger of electrocution oustide the prisons, but higher currents that may start a fire if a connector is bad.
If you need to ask the question, then you certainly shouldn't be using it!
"If you value your life, be somewhere else".
