Hello all,
i attempte to execute the following code:
===================================================== #include <LPC21xx.H>
void FIQ_Handler (void) __fiq; //declare FIQ ISR void initFiq (void);
void main (void) {
initFiq(); //Initilise the Fast interrupt source IOCLR1 = 0x00FF0000; while(1) { ; //Loop here forever }
void FIQ_Handler (void) __fiq { IOSET1 = 0x00FF0000; //Set the LED pins EXTINT = 0x00000002; //Clear the peripheral interrupt flag
But the compiler reports the error: main.c(27): error: #130: expected a "{" main.c(31): warning: #12-D: parsing restarts here after previous syntax error
can you help me please?
I use keil Arm uvision4. This code is from the Book: The Insider's Guide To The Philips ARM7-Based Microcontrollers An Engineer's Introduction To The LPC2000 Series. Thanks
use __irq instead. the RealView compiler does not support the "__fiq" token. the older CARM compiler - does.
Thank you for your Help,
it has worked
Best Regards
