i try to do the examples from the "Insider's Guide to the PHILPS ARM73" by the example 3 the compiler reports: main.c(31): error: #130: expected a "{" main.c(41): error: #130: expected a "{"
The code is very simple: ==================================================== #include <LPC21xx.H>
void thumb_function(void);
int main(void) __arm { IODIR1 = 0x00FF0000; ... }
void thumb_function(void) __thumb { ... } ==================================================== It seems the compiler not recognizes the "_arm"-Macro. I use the µVision V4.00 with the Keil-Compiler.
could you tell me how cann i set the Compiler in the µVision ? Thanke you for your help
It appears that this guide is referring to the Keil's CARM compiler. That compiler is long discontinued. These days Keil ship their software with the Realview compiler. Perhaps you are interested in '#pragma arm/#pragma thumb':
www.keil.com/.../armccref_BCFIJEAH.htm
Regards, - mike
