I'm trying to run the Keil example for the above board. 1/ I've moved J1 jumper to PD2. 2/ I built the software, but Uvision (3.8a) would not download it to the board ( siguv3arm.dll problem /). 3/ On a forum I discovered that you had to create a new project and 'import' all the example source code. This worked, and the LCD displayed MCBSTM32 HID.
4/ I've connected the board to my PC ( windows xp) via the USB lead. Sometimes it comes up with 'new device' etc. I told it that its a hid.
5/ I've run the hidclient.exe program, but it does not display the board. For device it displays <None>
6/ How can I get the above client to talk to my board ?
Hello Rowland Roderick,
Do you run the MCBSTM32 HID using a debugger?
Do you see the USB HID device in the windows device manager? Have you tried to uninstall the device in the device manager and reconnect the MCBSTM32?
Best Regards, Martin Guenther
Hello Martin Guenther.
1/ The board is connected through its JTAG connector to the ULINK2 and the USB connector to the PC.
I'm not running it in debug mode.
2/ Under Devices there are several entries under Human Interface Devices.
There is one labelled HID-compliant consumer control device.
There are two labeled HID-compliant device.
There are hree labeled USB Human Interface Device ( 2 of these are the keyboard and the other the ULINK).
So i'm not sure which one applies to the ST board so that I can uninstall it ?
If MCBSTM32 HID enumerates correct you will find two entries in device manager under section Human Interface Device:
- HID-complient device - USB Human Interface Device
If you display Properties for USB Human Interface Device you will see string Location 0 (Keil MCBSTM32 HID) under General - Location.
If you display Properties for HID-complient device you will see a string containing the idVendor(VID)/idProduct(PID) you used in usbdesc.c under Details - Device Instance ID like:
HID\VID_C251&PID_1C01\...
Now you should be able to identify the MCBSTM32 HID.
Dear Martin,
The only Keil entry is the Ulink. I can't find Keil mcbstm 32 hid
As you stated in usbdes.c idvendor & id product are 0xc251 and 0x1c01.
Rowland
Hello rowland Roderick,
Have you tried to set jumper J1 to GND and then reset the board?
Yes i've tried J1 to GND.
I also tried connecting the board to an old PC.
It came back with Unreconized Device, but it didn't have the driver.
for MCBSTM32 HID you do not need a special USB driver. XP detects it as HID device and uses the windows generic USB HID driver.
It seems that XP fails to enumerate the device.
