bootloader and rtx problem
I wrote a simple bootloader program (doesn't do anything but jump to the application code in flash once a timer expires) and I am having trouble getting rtx to work in the application code. It gets to a point in os_sys_init()'s assembly code where it will stick. I also find that all my other interrupts do not work either, although the lst file that it is generated seems to be putting the applications vector tables in the correct place...any ideas?
