I am using 89c55 Micorcontroller for my project. It has 20K flash memory. I want to calculate the checksum value in ROM location. I dont know the starting and end address of Flash ROM Memory, is there any bytes alloted in flash memory to store the checksum value? Suggest some links regardings this.... I also gone through the datasheet of 89c55 but they didnt mention the ROM location.
It has 20K flash memory. I dont know the starting and end address of Flash ROM Memory ???
is there any bytes alloted in flash memory to store the checksum value? NO
I also gone through the datasheet of 89c55 but they didnt mention the ROM location. ???
you seem totally lost it seems you do not even know that the '51 is Harvard. Maybe reading "the bible" would be helpful
here are the links to "the bible" Chapter 1 - 80C51 Family Architecture: www.nxp.com/acrobat_d...ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer’s Guide and Instruction Set: www.nxp.com/acrobat_d...UIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/acrobat_d...WARE_1.pdf
In the absence of any specific information to the contrary in the Dataaheet, you should assume that the general information in the so-called "bible" for the 8051 applies.
Erik has provided the links.
Thanks for ur Suggestion. But in the given link by u if I click means it says the "The requested page is not found". Can u give some other links regarding this to study.
Erik he is right NXP moved your links.
In short the chip does not know about checksums or CRCs. You can code them. The code starts at 0. The end is more work. You put the checksum where you want it. I would suggest the end of ROM. You can read the code with a C pointer qualified as "code"
Chapter 1 - 80C51 Family Architecture: www.nxp.com/.../80C51_FAM_ARCH_1.pdf
Chapter 2 - 80C51 Family Programmer's Guide and Instruction Set: www.nxp.com/.../80C51_FAM_PROG_GUIDE_1.pdf
Chapter 3 - 80C51 Family Hardware Description: www.nxp.com/.../80C51_FAM_HARDWARE_1.pdf
Erik: you seem to have copied the text with the "..." in it from some site that abbreviates URLs for display...
No, they haven't - fortunately!
Erik just managed to copy some "mangled" links!
a Scrolling matrix project covering 16 rows x 48 columns
SD card storing the display data so there is no need for the display to be connected to the computer Just load the display on the SD card and let it run.
what possible relevance does that have to this thread?!
Thanks for ur valuable suggestion
