respected sir
i m using lpc2378 and i m trying to implement i2c protocol with at24c512 eeprom when i m transmitting data then i m gettting ack but when i rx then i m not gettting ack pls tell m where is i m wrong
o/p of that program is ABCDA1A1FA185G
/******* i2c init *******/ PINSEL0 = 0x50; //Switch GPIO to I2C pins PCONP |= (1 << 19); PINSEL1 &= ~0x03C00000; PINSEL1 |= 0x01400000; /* set PIO0.27 and PIO0.28 to I2C0 SDA and SCK */ /* Initialize I2C */ I20CONCLR=0x6c; /* clearing all flags */ I20CONSET=0x40; /* enabling I2C */ I20SCLH=60; /* BIT FREQ 100 KHz & PCLK 12MZ*/ I20SCLL=60; while(1){ I20CONSET=0x60; Delay(100); if(I20STAT ==0x08) { IOCLR0=0x10; /* Slave address + write */ I20DAT=0xA0; /* Clear SI and Start flag */ I20CONCLR=0x28; /* Port Indicator */ IOSET0=0x10; TransmitChar0('A'); Delay(100); } if(I20STAT ==0x18) { /* Port Indicator */ IOCLR0=0x20; /* Data to be transmitted */ I20DAT=0xFF; //ADDRESS /* clear SI */ I20CONCLR=0x8; /* Port Indicator */ IOSET0=0x20; TransmitChar0('B'); Delay(100); // } // if(I20STAT ==0x18) // { /* Port Indicator */ IOCLR0=0x20; /* Data to be transmitted */ I20DAT='O'; //DATA /* clear SI */ I20CONCLR=0x8; /* Port Indicator */ IOSET0=0x20; TransmitChar0('C'); Delay(100); } if(I20STAT ==0x28) { IOCLR0=0x80; /* Transmit stop condition */ I20CONSET=0x10; /* clear SI */ I20CONCLR=0x8; /* Port Indicator */ IOSET0=0x80; TransmitChar0('D'); /*--- Wait for STOP detected ---*/ while( I20CONSET & 0x10 ); Delay(100); I20CONSET=0x20; I20CONSET=0x40; Delay(100); } /************** RECEIVER ******************/ if(I20STAT ==0x10) { I20CONCLR = 0x20 ; // if(I20STAT &=0x08) //Start bit I20CONCLR = 0x08 ; Delay(100); I20DAT = 0xA1; //Send address and write bit I20CONCLR = 0x08 ; TransmitChar0('E'); Delay(100); } if(I20STAT ==0x08) { IOCLR0=0x10; // Slave address + write I20DAT=0xA1; TransmitChar0(I20DAT); // Clear SI and Start flag I20CONCLR=0x28; // Port Indicator IOSET0=0x10; TransmitChar0(I20DAT); TransmitChar0('F'); Delay(100); } if(I20STAT ==0x40) //Slave address+r, ACK { // I20DAT = 0x0f; //Write Mem,ory start address to tx register // TransmitChar0(I20DAT); TransmitChar0(I20DAT); I20CONCLR = 0x08 ; Delay(100); TransmitChar0(I20DAT); TransmitChar0('G'); Delay(100); } if(I20STAT ==0x48) //Slave address+r, ACK { I20CONCLR = 0x20 ; // if(I20STAT &=0x08) //Start bit I20CONCLR = 0x08 ; Delay(100); I20DAT = 0xA1; //Send address and write bit I20CONCLR = 0x08 ; TransmitChar0('H'); Delay(100); // I20DAT = 0x0f; //Write Mem,ory start address to tx register TransmitChar0(I20DAT); I20CONCLR = 0x08 ; Delay(100); TransmitChar0('I'); Delay(100); } if(I20STAT ==0x50) //Slave address+r, ACK { TransmitChar0(I20DAT); /* Transmit stop condition */ I20CONSET=0x10; /* clear SI */ I20CONCLR=0x8; TransmitChar0('J'); } }
thank u
