Hi all,
I'm currently working on a bluetooth 8051 project and I'm going to interface a real time clock to the 8051 for time logging purposes.
Any useful real time clocks that I have found require an I2C bus, the problem is that the 8051 development board I'm using does not have an I2C bus, so I would like to implement one in software only in C using keil.
I'm quite stuck on how to do this, any guidence, references and examples of C code on how to do this would be greatly appreciated.
You can write your own I2C driver using the basic signal specifications that appear here:
www.esacademy.com/.../i2cproto.htm
