ADC of Xc167
Hello
Port 5 is not responding.
I have set the compatibility mode for regiseter.
at P5.6 and P5.8 is a voltage of 2.5 V created
I read from P5.6 and P5.8 a voltage.
The function does not work as I expect.
I expect to P5.6 ADC_DAT = 0x63FF read at 5V
or ADC_DAT = 0x6000 at 0V
But, I get at 5V or 0V the same result ADC_DAT = 0x6202
And I dont know how I read the voltage from the P5.6 or P5.8
I must set other register when I chose compatibilty mode ??
Thanks for Your Help
#include <xc167.h>
#include <intrins.h>
#include <XC16X.h>
void init ();
int AD_Strom_messung (int kanal);
unsigned int Strom_Wert,Strom1,Strom2;
int kanal;
void main (){      {
init ();
while(1)
Strom2 = AD_Strom_messung (6); // read P5.6 ====> 15F
Strom1 = AD_Strom_messung (8); // read der P5.5 ====> 15E
}//end of while
}//end of main
int AD_Strom_messung (int kanal){
 ADC_CON = kanal + 0x0080 ;      // Select Channel und start Conversion
 do {
 }while (ADC_CON & 0x0100);// wait of end Conversion
Strom_Wert = ADC_DAT & 1023 ;//read ADRES of ADC_DAT
return Strom_Wert;
void init ()
ADC_CON1 = 0x0104 ;
P5DIDIS  = 0xFFFF ;
