"isr_evt_set "problem
Hi All:
I have a problem when I use “isr_evt_set†in my UART interrupt routine:
It ca not reach to “ os_evt_wait_or(0x0001,0xffff);â€
But if I just change “isr_evt_set†to “os_evt_setâ€, my code works fine.
Anybody knows what’s wrong? I am using MCB2300 board.
Part of code here:
void UART3Handler (void) __irq
{  isr_evt_set(0x0001,UART3_TASK);
  /*use "os_evt_set" works*/
   VICVectAddr = 0;             /* Acknowledge Interrupt */
void task_UART3_received (void) __task
  BYTE IIRValue, LSRValue;
  BYTE Dummy = Dummy;
  for(;;)
can not get here if I use "isr_evt_set":
Jack
  • Sorry some chars can not be read, post my question again:
    Hi All:
    I have a problem when I use "isr_evt_set" in my UART interrupt routine:
    It can not reach to "os_evt_wait_or(0x0001,0xffff);"
    But if I just change "isr_evt_set"to "os_evt_set", my code works fine.
    Anybody knows what's wrong? I am using MCB2300 board.
    see my code above
    Jack
    Hi All:
    see my code above
    Jack
