Hi .... i want to display the temperature in pc and control motor speed from pc through USB .im using lpc2148 MCU.. my doughty is first i want to write the drivers in PC and next in lpc2148 MCU side or no necessary to write device driver at pc side only driver at LPC2148 MCU. im using Windows XP.... please help me
You first have to say what work you have done, that you need help with.
Or haven't you looked at any examples?
i write all code regarding temperature display in LPC2148 board but i want to display in pc
And what USB examples have you looked at?
What USB examples have you tried to run?
What USB code have you got working, and where have you got stuck?
What USB documentation have you read?
What are you currently working with, regarding USB?
I am referring Axelson_J.USB_Complete and im referring Keil lpc2148 USB-HID code one thing im not understand is that in USB-HID code two separate code one for Board and anther RV what is that
Any one help me which is good book for usb
http://www.keil.com/usb/
