UART RX interrupt
Hi, I am using the STR912FA and I am trying to implement the UART communication using interrupts. I am using the interrupt only for receiving data, but for some reason I never get an interrupt when writing a character in the hyperterminal ...
The transmition works ok using the printf to the hyperterminal.
Does someone see something wrong in my code?
Thanks a lot!
This is my UART initialization:
// UART  Module
  UART_InitStructure.UART_WordLength = UART_WordLength_8D;
  UART_InitStructure.UART_StopBits = UART_StopBits_1;
  UART_InitStructure.UART_Parity = UART_Parity_No ;
  UART_InitStructure.UART_BaudRate = 115200;
  UART_InitStructure.UART_HardwareFlowControl = UART_HardwareFlowControl_None;
  UART_InitStructure.UART_Mode = UART_Mode_Tx_Rx;
  UART_InitStructure.UART_FIFO = UART_FIFO_Disable;
  UART_DeInit(UART0);
  UART_Init(UART0, &UART_InitStructure);
  UART_Cmd(UART0, ENABLE);
  UART_ITConfig(UART0, UART_IT_Receive, ENABLE);
  VIC_DeInit();
  VIC_Config(UART0_ITLine, VIC_IRQ, 2);
  VIC_ITCmd(UART0_ITLine, ENABLE);
This is the interrupt (That I never get):
void UART0_IRQHandler(void)
 /*clear receive interrupt flag*/
  UART_ClearITPendingBit(UART0, UART_IT_Receive);
  //UART_ClearITPendingBit(UART0, UART_IT_Transmit);
  /*send back the received character*/
  while(UART_GetFlagStatus(UART0, UART_FLAG_TxFIFOFull) != RESET);
  UART_SendData(UART0, UART_ReceiveData(UART0));
This is my byte transmition (works):
int MyLowLevelPutchar(int x)
    UART_SendData(UART0, x);
    while(UART_GetFlagStatus(UART0, UART_FLAG_TxFIFOFull) == SET);
  return x;
