I am using the LPC-E2468 OEM board from Embedded Artist. I am using the ULINK2 for programming and debugging. I read all of the message I can find on the Keil forum and I tried the flashmagic tool for the LPC part. I am still in square zero!
Regarding flashmagic, I got the autobaud failure on both usb-serial or real serial on the docking station. I tried changing the baud rate but it still did not work. By the way, I am using a null model cable since both 9-pin connectors are male. I am sure if I need to do that.
Regarding the ULINK2, I tried just about everything suggested on the forum but it just does not work. Is there someone out there experience what I am experiencing? Can someone help me please?
Best regards
Thomas Yuen
I would guess that conclusion was premature. In an ideal world, connector gender on a RS232 socket was supposed to mean something. Out here in reality it doesn't.
So forget about connectors, and look at (or oscilloscope) the actual pin-outs. That'll tell you if you need a crossed cable or a straight one.
