Use of os_xx_functions in callbacks
Is it safe to use such functions as os_mbx_send inside a call back function ie. udp_callback from the TCP stack, i have this working and all seems ok, i am passing messages from the udp socket inside my tcp_task , to a serial port handled via another task.
However, i am now trying to pass messages from the cgi_function callback again in the tcp_task, to my serial port task, this works to a point, it appears the messages are sent to the serial port handler i can see the messages on the wire with my serial monitor and the reply messages are going back, the other way from the serial port to the tcp_task mailbox, i can see the pointer in the mailbox. But the task appear to be locked, my other tasks are still run the i have task hadling the timer function for the TCP stack this is still active, in the RTX monitor the tcp_task states it is ready, it is as if the TCP task has been left in a locked state.
Still looking deeper but just wanted confirmation that its safe to call os_mbx_send from the callback functions.
best regards
Darren
