I am experiencing what seems to be a spurious SWI call. The effect is that the application hangs on the SWI Handler __asm void SWI_Handler (void):
SWI_Dead BHS SWI_Dead
What can I do to identify the origin of this spurious call?
The ARM processor is the LPC2387. I am using Keil RTOS and compiler version:
IDE-Version: µVision3 V3.80 Copyright (c) Keil Elektronik GmbH / Keil Software, Inc. 1995 - 2009
Tool Version Numbers: Toolchain: RealView MDK-ARM Version: 3.50 Middleware: RL-ARM Real-Time Library Version V3.50 Toolchain Path: BIN40\ C Compiler: Armcc.Exe V4.0.0.524 Assembler: Armasm.Exe V4.0.0.524 Linker/Locator: ArmLink.Exe V4.0.0.524 Librarian: ArmAr.Exe V4.0.0.524 Hex Converter: FromElf.Exe V4.0.0.524 CPU DLL: SARM.DLL V3.50 Dialog DLL: DARMP.DLL V1.44 Target DLL: BIN\UL2ARM.DLL V1.47 Dialog DLL: TARMP.DLL V1.44
Regards, Andre
this is very a general problem report. you must provide details - R14 value, when and where it happens etc.
The situation is as follows: The software runs communicating through a CAN interface. After approximately 5 minutes it hangs up in a SWI_Dead loop. Analysing the call stack, the SWI call occurred from inside a function called from an interrupt routine, in the sequence below (CAN_Handler is the interrupt routine) CAN_Handler() -> CAN_RX2_ISR() -> CAN_hw_rd() -> SWI??
The problem is there is no explicit call to SWI from inside CAN_hw_rd().
// detail from CAN_hw_rd() :
0x00032100 E2402001 SUB R2,R0,#0x00000001 378: regCAN *ptrcan = (regCAN *) CAN_BASE[ctrl0]; 379: 0x00032104 E59F4780 LDR R4,[PC,#0x0780] 0x00032108 E794E102 LDR R14,[R4,R2,LSL #2] 381: CANData = ptrcan->CANRFS; 0x0003210C E59E3020 LDR R3,[R14,#0x0020] 382: msg->format = (CANData & 0x80000000) == 0x80000000; 0x00032110 E1A04FA3 MOV R4,R3,LSR #31 0x00032114 E5C1400E STRB R4,[R1,#0x000E] 383: msg->type = (CANData & 0x40000000) == 0x40000000; 0x00032118 E2034101 AND R4,R3,#0x40000000 << spurious SWI call 0x0003211C E1A04F24 MOV R4,R4,LSR #30 0x00032120 E5C1400F STRB R4,[R1,#0x000F] 384: msg->len = ((U8)(CANData >> 16)) & 0x0F; 385: 0x00032124 E3A0400F MOV R4,#0x0000000F 0x00032128 E0044823 AND R4,R4,R3,LSR #16 0x0003212C E5C1400C STRB R4,[R1,#0x000C] 387: msg->id = ptrcan->CANRID; 388: 0x00032130 E59E4024 LDR R4,[R14,#0x0024] 0x00032134 E5814000 STR R4,[R1] 390: if (msg->type == DATA_FRAME)
Thanks a lot,
