Hi. I designed an ARM7 board with LPC2478 MCU. Unfortunately, JTAG doesn't work like one would expect.
I can download code to FLASH, I can start debugging, BUT every time it comes to the first STR instruction I get "Could not stop device" ERROR. When I don't step the code it goes to some garbage address.
I have ONLY ONE physical pull-up/down resistor on my JTAG 2x10 connector (device is ULINK(non2)).
TCK is pulled to +3.3V with 10k resistor.
Signals DBGEN, TMS, TDI, nTRST, RTCK are terminated inside LPC2478.
I saw on some boards that TCK is pulled down? Is this the source of my problem ?
Ivan
Hello Ivan Dodig,
Please have a look at support knowledgebase article http://www.keil.com/support/docs/3030.htm
LPC2478 also has this bootcode which causes trouble during single step.
Best Regards, Martin Guenther
Hi ! Thanks for you're help.
