SPI clock and C8051F020
I program SPI protocol for an MCU C8051F020 with Silicon Laboratories IDE.
My problem is : the spi clock isn't generate and i don't see the signal clock on the scope.
Here is my code :
// Includes
#include "c8051f020.h"                // SFR declarations
#include "spi_defs.h"
// 16-bit SFR Definitions for 'F02x
sfr16 DP       = 0x82;                 // data pointer
sfr16 TMR3RL   = 0x92;                 // Timer3 reload value
sfr16 TMR3     = 0x94;                 // Timer3 counter
sfr16 ADC0     = 0xbe;                 // ADC0 data
sfr16 ADC0GT   = 0xc4;                 // ADC0 greater than window
sfr16 ADC0LT   = 0xc6;                 // ADC0 less than window
sfr16 RCAP2    = 0xca;                 // Timer2 capture/reload
sfr16 T2       = 0xcc;                 // Timer2
sfr16 RCAP4    = 0xe4;                 // Timer4 capture/reload
sfr16 T4       = 0xf4;                 // Timer4
sfr16 DAC0     = 0xd2;                 // DAC0 data
sfr16 DAC1     = 0xd5;                 // DAC1 data
// Global CONSTANTS
#define SYSCLK       22118400          // SYSCLK frequency in Hz
sbit LED = P1^6;                       // LED='1' means ON
sbit SW1 = P3^7;                       // SW1='0' means switch pressed
// Function PROTOTYPES
void SYSCLK_Init (void);
void PORT_Init (void);
void SPI0_Init (void);
void Timer0_ms (unsigned ms);
void Timer0_us (unsigned us);
// Global VARIABLES
// MAIN Routine
void main (void) {
   WDTCN = 0xde;                       // disable watchdog timer
   WDTCN = 0xad;
   SYSCLK_Init ();                     // initialize oscillator
   SPI0_Init;
   PORT_Init ();
   while (1){
   Timer0_ms(500);
   LED=~LED;
// Initialization Subroutines
// SYSCLK_Init
// This routine initializes the system clock to use an 22.1184MHz crystal
// as its clock source.
   int i;                              // delay counter
   OSCXCN = 0x67;                      // start external oscillator with
                                       // 22.1184MHz crystal
   for (i=0; i < 256; i++) ;           // XTLVLD blanking interval (>1ms)
   while (!(OSCXCN & 0x80)) ;          // Wait for crystal osc. to settle
   OSCICN = 0x88;                      // select external oscillator as SYSCLK
                                       // source and enable missing clock
                                       // detector
// PORT_Init
// Configure the Crossbar and GPIO ports
//P0.4 - MOSI (push-pull)
//P0.3 - MISO
//P0.2 - SCK (push-pull)
//P0.0 - UART TX (push-pull)
//P0.1 - UART RX
   XBR0 |= 0x06;                         //Enable UART pins and SPI0 pins
   XBR1    = 0x00;                     // System clock routed to port pin
   XBR2    = 0x40;                     // Enable crossbar and weak pull-ups
   P1MDOUT |= 0x40;                    // enable P1.6 (LED) as push-pull output
   P0MDOUT |= 0x15;                    // enable P0.2 (CLK) and P0.4 (CONV) as push-pull output
                                      // P0.3 (Data) as push-pull input and UART TX (push-pull) output
// SPI0_Init
SPI0CFG = 0x07; //data sampled on 1st SCK rising edge
                //8-bit data words
SPI0CN  = 0x03; //Master mode ; SPI enabled; flags cleared
SPI0CKR = 0x04;  //SPI clock rate
// Timer0_ms
// Configure Timer0 to delay <ms> milliseconds before returning
 unsigned i;      //millisecond counter
 TCON &= ~0x30;   //STOP Timer0 and clear overflow flag
 TMOD &= ~0x0f;   //configure Timer0 to 16-bit mode
 TMOD |= 0x01;
 CKCON |= 0x08;   //Timer0 counts SYSCLKs
 for (i=0;i<ms; i++) {
   TR0 = 0;         // STOP Timer0
   TR0 =(-SYSCLK/1000)>>8;  //set Timer0 to overflow in 1ms
   TL0 = -SYSCLK/1000;
   TR0 = 1;                  //START Timer0
   while (TF0 == 0);     //wait for overflow indicator
   TF0 = 0 ;              //clear overflow indicator
// Timer0_us
// Configure Timer0 to delay <us> milliseconds before returning
 TMOD |= 0x01;
 for (i=0;i<us; i++) {
   TR0 =(-SYSCLK/1000000)>>8;  //set Timer0 to overflow in 1ms
   TL0 = -SYSCLK/1000000;
Can you help me ?
Regards
