I'm working with RLARM and I have to start designing a USB application. In the datasheet of RLARM you can read some stuff about RL-USB stack. OK ... But when you look at the help file , nothing about usb , no library , no doc, just some examples !
I missed something ?
try here: ", including documentation.
Thanks , but I just forgot to mention : I'm using LPC23xx :)
you is be misseding it yes?
looking to the file rl_usb_user_guide.pdf
i sawed it in c:\keil\arm\hlp you be knowing good
Thanks,
I missed it because it doesn't appear in the help file of RL-ARM (chm). Strange it's the only pdf file ...
