Accessing mapped global variable by reference
I'm using the LPC2468 micro controller. I have a struct mapped to the I2C register and in the I2C interrupt I statically access that struct, and everything works fine.
I've since broken off into a separate function the processing part of the interrupt code and now the interrupt passes a reference to its register to that function (so I can use one function for the three I2C buses). And suddenly the code doesn't work. Just to make sure I didn't mess up anything when creating the new subroutine, I replaced all the by-reference register accesses with a static call, and it worked again. I also verified that the reference points to the correct address.
So, it seems that when accessing the register statically, it works, and when accessing by reference it doesn't work. I can't figure out why. Does anyone know what I'm doing wrong? Or is there some technical reason why this won't work?
Here's a code snippet:
struct i2c_regs {
        U32 I2CONSET;
        U32 I2STAT;
        U32 I2DAT;
        U32 I2ADR;
        U32 I2SCLH;
        U32 I2SCLL;
        U32 I2CONCLR;
} __attribute__((packed));
struct i2c_data {
        volatile struct i2c_regs *regs;
        U8 len;
        U8 pos;
        U8 addr;
        char *buf;
        char *base;
        U8 state;
        OS_MUT lock;
        OS_SEM sem;
static volatile struct i2c_regs i2c0_regs __attribute__((at(I2C0_BASE_ADDR)));
static struct i2c_data i2c0;
// i2c0.regs is properly initialized
void i2c0_handler(void) __irq
        IENABLE;
        i2c_master_handler(&i2c0);
        IDISABLE;
        VICVectAddr = 0;
static void i2c_master_handler(struct i2c_data *i2c)
        int status;
        status = i2c->regs->I2STAT;
        switch(status) {
            case I2C_STATUS_START:
#if 0
                // Doesn't work
                i2c->regs->I2DAT = i2c->addr;
                i2c->pos = 0;
                i2c->buf = i2c->base;
                i2c->regs->I2CONSET = I2CONSET_AA;
                i2c->regs->I2CONCLR = I2CONCLR_SIC|I2CONCLR_STAC;
#else
                // Does work
                i2c0_regs.I2DAT = i2c->addr;
                i2c->pos = 0;
                i2c0_regs.I2CONSET = I2CONSET_AA;
                i2c0_regs.I2CONCLR = I2CONCLR_SIC|I2CONCLR_STAC;
#endif
                break;
Thanks,
Jon
