Build target 'Target 1' assembling STARTUP.ASM... 89C51RE2.H(17): error A10: ATTEMPT TO DEFINE AN ALREADY DEFINED SYMBOL
This is line 17 in the header file /* BYTE Register */ Sfr (P0 , 0x80);
When I compile modules in Microvision3 I got error A10 error on the include file header 89c51RxD2.h If I comment lie 17 out.. I will get error undefine symbol later.
I select the Device as 89C51RE2 in the IDE It works OK in DOS compilers.
How do I solve this problem?
http://www.keil.com/support/man/docs/a51/a51_a10.htm
http://www.keil.com/support/man/docs/a51/a51_nomod51.htm
