as suggested by the help link i looked for the result to see the message in the memory1. but i found only nop in the disassembly window. what is the error? why i m getting this sort of error. please help me.
i mean i found such problem while compiling and simulating simple display message for lcd in microvision3.
Look at Andy's response to your other thread.
Your problem statement is not very clear.
What are you trying to do? What did you expect to see in the Memory1 window? what memory addresses are you looking at?
I'd like to help, but I can't understand what the problem is from you description.
ND
"Your problem statement is not very clear"
I like to come in just under the wire like that :)
