Individual HEX File for Each Code Bank
If you require a single HEX file for each code bank, you must create a batch program that runs OHX51 once for each code bank. The contents of the batch file will be similar to:
OHX51 my_program RANGE (B0:0 - B0:0xFFFF) HEXFILE (my_program.H00) OHX51 my_program RANGE (B1:0 - B1:0xFFFF) HEXFILE (my_program.H01) OFFSET (-0x10000) OHX51 my_program RANGE (B2:0 - B2:0xFFFF) HEXFILE (my_program.H02) OFFSET (-0x20000) This effectively generates the same output files as the BL51 Linker using the OC51 and OH51 utilities.
MORE INFORMATION
Question? -------- What's format of the my_program (file extension) using LX51 and ohx51?
It's Keil's own format. Meaning you don't need to know, and you don't get to know.
