newbie questions about the stack and the stack size
Hi
I have a few questions about the stack size (LPC2200 controller).
E.g. in my programm is a main function with an array
short example[16][500];
16 * 500 * 4 (short) = 3,9 kByte
In which value will I find this array in the calculation when I rebuild all files (code, RO-data, RW-data, Zi-data)?
Moreover is it true, that the stack size will be configurated in the startup file? And the default value is 0x400 for the user stack - so I would need a much bigger value for the user stack?
After a few minutes I saw the map file where I figured out that the stack is growing from a low base.
In my case at the beginning of the internal ram there's a libspace (atmel-lib and string.h) and after that there's the heap (size = 0) and the stack size...
Is it ok, to increase the stack size up to the highest addr from the internal RAM?
best regards
Albert
