Program hangs on machine if code size is greater than 44K
I am using M27C512 chip. I am noticing that if code size is less than 44K, the obj works fine. As soon as it goes even 1 byte above 44K, program still compiles fine but when it is fired to controller program hangs anywhere in between when running. Is there any restriction on code size?
