I am kind of confused about using the _at_ keyword to assign a specific address to a variable.
so for example :
extern xdata char variable _at_ 0x000f;
it fills 3 bytes in xram . can any one explain how is the compiler handling these sequence. Thank you !
Are you sure that line of code is exactly what you are compiling?
It seems neither of you read the manual and realized the glaring mistake.
BTW it fills 3 bytes in xram is definitely wrong, but not the issue
...that does not make whatever module the variable is in know where to put it
That's quite a common newbie misunderstanding of 'extern'.
Despite your protestation, Jack, it seems that Erik was right this time around. Have you noticed the warning generated by the RealView compiler?
Let's look at what he actually said:
the _at_ must be in the declaration of the variable
Wrong - it must be in the definition of the variable, as it is in the example given.
not in an extern ref
Wrong - the example given isn't an 'extern ref'.
Wrong - the toolchain knows exactly where to put it.
Your use of a compiler extension in a compiler I am not familiar with is entirely your own problem. I suggest you check the compiler documentation.
Why should "the standard" contain any information on how a C compiler handles non-standard extensions?
'extern' is not a non-standard extension. It's probably better if you don't snip away the context like that.
Come on. You know that I was not referring to extern.
The context says that Erik should compile a line that contains not just one, but two blindingly obvious non-standard keywords and look at the resulting assembly, and that he would find the explanation for the results in "the standard".
Yes?
I think the sardine should change his monniker to Nit Pick
extern xdata char variable _at_ 0x000f; the _at_ must be in the declaration of the variable Wrong - it must be in the definition of the variable, as it is in the example given. 1) definition/declaration can be found as synonyms in any crossword handbook. 2) an extern is NOT a definition, it is a reference
not in an extern ref Wrong - the example given isn't an 'extern ref'. if tha example is not an external reference what is it then?
that does not make whatever module the variable is in know where to put it Wrong - the toolchain knows exactly where to put it. obviously it does not.
"1) definition/declaration can be found as synonyms in any crossword handbook."
C, however, makes a distinction between the two:
c-faq.com/.../decldef.html
But, as already noted, we are not talking about crossword puzzles! We are talking about the 'C' programming language, where the terms have specific, distinct meanings - and a thorough understanding of the distinction is key to this thread!
"2) an extern is NOT a definition, it is a reference"
No, it is not a reference, it is a declaration
I stand corrected re verbiage; however the reason I stated for the problem (extern combined with _at_) was correct and the OP changed accordingly and now states "it works".
Yes, but equally you know that I was not referring to __at__.
Yes. The code posted does not behave the way he thinks it does, this is because of is his misunderstanding of 'extern'.
"Warning--A message emitted by a compiler to try and convince the programmer that some program construct is likely confusing, wrong, or dangerous. Because of the serious nature of warnings, most compilers have a provision to turn most of them off. The rest typically go to /dev/null."
You were referring to a declaration that contains non-standard keywords, and basically by definition the standard cannot describe what the compiler should do with such a line.
Interestingly enough, the compiler documentation contains detailed examples on how to define variables using the _at_ keyword, and how to use these variables in a different source file than they were declared in.
You are missing the point. The issue in hand is that the 'extern' keyword, when applied to a variable definition, does not make it an "extern ref".
I should hope the manual documents the usage of all non-standard extensions.
Thank goodness for that.
Well actually, the problem reported was this:
And you replied:
Yet you are now claiming it was intended as a fix for the issue. Can you explain?
when the mistake is glaring, I usually provide a hint rather than a solution (I know that a hint will lead to better understanding if the asker work on the hint), then when both the OP and you gave up I posted
the _at_ must be ... not in an extern
and, amazing to you, I am sure, the 3 byte issue disappeared
Jack, Erik, I need to apologize to you. My posted test above was wrong in the sense that when using the RealView compiler, one should make the declaration like this:
extern int variable __attribute__((at(0x8000))) ;
and not like the original version, which was
extern int variable __attribute__((__at(0x8000))) ;
when the first one is used - no warning is generated!
