Hi, Can anyone tell me what is the byte ordering in C8051F020 SiLabs Microcontroller? Whether it is a Little Endian or Big Endian?
Whatever you want. However you will obviously let your assembler/compiler/linker decide for you.
the only 'byte ordering' there is in the actual controller is for the mov dptr,# (the only 16 bit operation in the processor) and the bible tell you what that is.
There are, however, some other 16-bit SFRs.
You have to load the bytes individually - but, again, check in the Datasheet for the order.
Note that Keil's sfr16 does not necessarily match a specific chip's required order...
There are, however, some other 16-bit SFRs OK, but they are not "in the processor" and the 'byte ordering' is not mandatory. Yes it is 'standardized' for the 'traditional, but were I to design a chip (fat chance) with a 16 bit register I could legally put the high and low byte SFRs in any order, even far apart, should I wish.
also there are no "16-bit SFRs" but some interface registers that are associated with 2 (8 bit) SFRs to make a 16 bit register
