I'm using Keil uvision V3.62c and I tried to use the GNU V3.22 with uclib to compile the Blinky example. As assembling Startup.s I have the folowing message: arm-uclibc-as: unrecognized option '-gdwarf-2'
The right option should be '--gdwarf2' but I don't know how changing the 'Compiler control string'
hello Philippe NIPPERT,
Have you got the program working on Keil Using GCC compilers. Now i 'm facing the same problem. Canu help me.
