can any one give the correct syntax for HEX2BIN CONVERSION. I refered in the website it is not clear and it is not working . thanks in advance
Are you saying that the syntax given at http://www.keil.com/download/docs/7.asp is not correct?
Syntax: HEX2BIN [/option] hexfile [binfile] hexfile is the Intel HEX input file binfile is the binary file to create option may be any of the following /Ln Binary file length /Pn Pad data for binary file /On Address offset (to add to HEX records) /M Merge data into existing BIN file /Q Quiet mode (no statistics are displayed) /X Don't process ext. segment/linear address records /? This help text
If myfile.hex has gaps and I want to keep the gaps in erased state I'd fill them with FF.
Both HEX2BIN /f0xff myfile.hex and HEX2BIN /f255 myfile.hex fill the gaps with 00 and not FF as I expected.
found a better one at sourceforge.net/.../showfiles.php
