ULINK2 and ARM7 ETM (Embedded Trace Module)
Is ULINK2 able to handle the ETM module?
I'm evaluating the purchase of the ULINK2 and I'd like to understand which are the advantages respect other kind of USB-JTAG interfaces. I'm starting with ARM7 NXP LPC2378/LPC2368.
Thank you in advance,
Maurizio Malaspina
  • This is really a question for Keil sales but the uLink2 does not support the ETM. Keil supports a set of Seggar tools that do support the ETM module.
    But I do have one suggestion. Look at the RT-Agent from Keil. It can extend the uLink2 support that might satisfy your immediate debug requirements.
    I use the uLink2 and have excellent results with the MCB23xx eval board with the LPC2378 device. I cannot run at the full 1 MHz JTAG clock rate but I can run at 500 KHz with no problems.
    I have heard from a National Instruments Rep that LabView interfaces with the Keil uLink2. I have not yet used this feature. Hope to test it in the near future.
    Bradford
    Bradford
