Hello there, I start a thread cause I'm stuck in my development and it seems that I cant define breakpoint any more. My microcontroller is a stm32f101c8t6. I used to work on the Keil model based on the stm32f103ze and I never had any problem. Is there a limitation (i know that the number of breakpoints can vary but in my case I cannot event put only one breakpoint). I did not find what to do in the RM0008, thats why I'd be pleased that someone helps me. Thanks in advance
I found my mistake, in the debugger settings (debug tab) I checked the download option "Download to flash" and when I do that breakpoints are not available on the C code, only on the assembly. When it is unchecked, everything works as usual (I can put a breakpoint on a C file). I wondering why cannot I download the code to flash to use breakpoints ? Thanks in advance
I forgot to say that my debugger is a ULink2, hence it should be able to insert breakpoint and indeed it worked on my model but not on my prototype, still doesnt work :(
maybe this helps?
http://www.keil.com/ulink/cmp.asp
