how 2 intialize at89c51ed2 for spi communication with ds1306?
2 initialize datasheets.
Thank you for your reply sir. i have return this code. #include <REG51xD2.H> #include<stdio.h> #include<stdlib.h> unsigned char SPI(unsigned char);
void sdelay(int ); void main(void) { EA=1; SPSTA=0x00; SPCON=0xd6;
P1_7=1;//mOsi
P1_6=0;//sck P1_6=1; P1_1=1;//ss sdelay(1);
SPI(0x80); SPI(0x55); SPI(0x58); SPI(0x16); SPI(0x3); SPI(0x19); SPI(0x10); SPI(0x04); P1_1=0; sdelay(1); }
unsigned char SPI(unsigned char mybyte) {
SPDAT|=mybyte;
while(!(SPSTA&0x80)) { ; }
SPSTA&=0x00; return SPDAT;
void sdelay(int ms) { unsigned int i,j; for(i=0;i<ms;i++) for(j=0;j<135;j++);
here the value is not getting transmitted to SPDAT register.. I don't know what is the problem wiht this code
"i do not understand, code has comments, I see none."
As a sentence, that one makes no sense.
"i do not understand that you state "here is my code", code has comments, I see none."
is that better?
"is that better?"
A little better ;)
This may be considered better:
I do not think you are right when you say "here is my code". Code has comments. I see no comments in your post. It could therefore be deduced that you have not actually posted any code for us to view.
I do admit, however, that mine is way longer than yours.
ps I totally agree with the sentiments of your original post.
I have written the comments plz go through it #include <REG51xD2.H>
void SPI(unsigned char);
EA=1; SPSTA=0x00; SPCON=0xd6; /*MSTR(4th bit),SPEN(7th bit),CPHA (2nd bit),7th,0th & 1st bits are enbled. the 7th ,0th & 1st bits are enbled for Fclk Periph/128*/
IEN1=0x04; /* enable spi interrupt */
P1_7=1;/*mOsi enable*/ P1_6=1;/*sck enable*/ P1_1=1;/*slave select*/ sdelay(1); SPI(0x80);/* send an example data */ sdelay(1); while(1); }
void SPI(unsigned char mybyte) {
SPDAT=mybyte;/* read receive data */
while(!(SPSTA&0x80))/* set software flag */ { ; }
SPSTA&=0x7f;
I hav written the comments plz go through it. #include <REG51xD2.H>
EA=1; SPSTA=0x00; SPCON=0xd6; /*MSTR(4th bit),SPEN(7th bit),CPHA(2nd bit),7th,0th & 1st bits are enbled. the 7th ,0th & 1st bits are enbled for Fclk Periph/128*/
Why did you post your code THREE times?
Why did you not place your code in 'pre' tags so we could read it more easily?
Comments ... Hmmmm.
Sausage man, Have you noticed the widespread of C based delay loops (here and in other threads)? what is it with teachers today? even they can't get their act together?!?!?!
"Have you noticed the widespread of C based delay loops..."
Unfortunately, I don't think it's just teachers who are to blame for this.
There are a number of manufacturer examples that do the very same thing. I've certainly seen ST and PIC code that contains it.
When I was getting my (precious few) qualifications, I was frequently told by the lecturers that we shouldn't concern ourselves with code efficiency because "tomorrows processors will be faster".
At the time I thought that was b#@@sh1t - And I still do!
At the time I thought that was b#@@sh1t - And I still do! 1) I agree this is male cow manure 2) you did not mention that when "tomorrows processors" are inserted the delay loops will be faster too, OOPS
SPI(0x80);/* send an example data */ ..... SPDAT=mybyte;/* read receive data */
but they will also be given more to do - so there is no end to the challenge of fitting everything the customer wants into the resources that he's prepared to pay for...
Another factor is that more and more equipment will be driven on batteries at the same time as they are expected to be smaller and smaller.
Not needing the extra speed of that new processor, and instead downclocking it or putting it to sleep means the battery can be smaller, or the unit can run a longer time.
Isn't it enough that Windows and a lot of application developers increases the power consumption of our PC:s with 20-100W just because they like nice graphic screen savers and requires everything to be animated?
I recently noticed that some of my Blu-ray disks overrides the players "screen saver" which means that the player will consume a lot more power, and - even more importantly - will not power down itself and the projector if the movie is left on pause too long...
Isn't it enough that Windows and a lot of application developers increases the power consumption of our PC:s with 20-100W just because they like nice graphic screen savers and requires everything to be animated? the real point is that while everybody is on the butt of Dell et al to make "green machines" nobody is on Microsofts butt because Hasta la Vista requires a twice as powerful (twice as power hungry) PC for the same performance.
Some people should maybe kick Intel too - they have many, many releases that gulps huge amounts of power.
When they released the 8W Atom processor, they combined it with a chipset eating more than 20W, so many reviews erroneously discusses the "processor fan" when looking at the chipset HSF.
