UDP transmission
I'm developing an application for an ARM9 uC, on the evaluation board MCB-STR9.
I'd like to use the RTOS (RTX application) and implement in a RTOS task a UDP based transmission protocol. Even if I extensively read the documentation, I didn't have any luck to see my application working so far. Actually, I also tried to copy/paste the UDP transmission sample on the documentation,
www.keil.com/.../rlarm_tn_using_udpsoc_example.htm
in the http_demo example environment, to somehow correct the code in order to compile it, but still I didn't see anything coming out.
Am I missing something?
RL-ARM TCP/UDP communication setting doesn't seem that complicated...
My subnet has a DHCP addressing.
Can it be the cause? (config settings - DHCP assigned IP missmatch)?
Sorry for this stupid question, sure it's due to not good product knowledge, but any help is welcome :)
Thank you in advance
Sarah
